Sonex1517 wrote: It was the AeroInjector needle adjustment screw moving a tiny bit. Once I peened the threads and re-tuned, it went away for good....
scotttro wrote:Robbie, how did you manage to peen such small threads?
Bryan Cotton wrote:I think I did a squeeze with pliers.
The engine is trying to run BACKWARDS!! I think when I first detected detonation it was a noticeable vibration. I was climbing after take off still producing full power/rpm (33" 3000 rpm was what I was use to) so I pulled the throttle out a little and it went smooth. When I got my waste gate fixed did a NOT full power take off and landed half hour later at another ap taxied back for take off and on climb (37" 3100 rpm) out terrible vibration and rpm drop--pulled throttle and it smoothed out came back around and landed. Did some ground tests and over 35" the vibration would kick in and under 35" it would run smooth. As I said above switching off the secondary solved the problem. This will be the 3rd time I've retarded my secondaries--- I had them waaaay advancedRynoth wrote:I'm curious, what is the sensation (physical, audible) that leads you to believe it's detonation?
Users browsing this forum: No registered users and 67 guests
