by sonex1374 » Mon Feb 10, 2020 11:20 pm
Andre,
Some of the regulators suitable for use on an AeroVee have a visible shunt connection in the regulator's terminals, others are internal. I suspect that your replacement regulator is internally shunted. My advice is to connect the new regulator the same way as your old one and test run the engine. Remember, if you use a regulator terminal to pick up the rpm signal, only one of the AC input terminals will provide a tach signal. Trial and error will determine which terminal is the proper one.
Jeff
