The little Old Engine That Could
Re: The little Old Engine That Could
Postby Onex107 » Tue Aug 06, 2019 9:50 am
Onex107 wrote:You can't have anything in the valve guide while reaming. Dental floss? Wire? Not. If you could tie it to the end of the reamer and push it ahead as you reamed, then pull it back through, that would work. Special reamer for the rope trick? How about a magnet? Very tricky problem.
Sorry, I wasn't thinking. Wire or floss would lie in between the reamer flutes and help guide the stem back into the guide. I didn't know there was enough clearance for something tied around the end of the stem.
OneX 107
N2107X
Onex107
Users browsing this forum: dreyn96, flyguy0609 and 15 guests
