kmacht wrote:If the engine was involved in a prop strike (I think your other posts said you nosed the plane over during taxi) then it should be removed and FPI'd. You may find that a new cam and gear is cheaper than the inspection though.
Are the connecting rods and crank new? If so then they can go anywhere but most people try to match connecting rods, pistons, and pins so that they all have similar assembled weights. If the connecting rods and crank are being re-used then you want to install them back to the same piston and crank journal as they were before. If you aren't sure which one went where or only one of the two (crank or connecting rods) are new then you will want to get some plastigage to measure the clearances between the bearing surfaces to make sure everything is within tolerance.
Also, the above is just my opinion. I would recommend calling Sonex to find out what they suggest.
#554
kenandkatie2 wrote:Thanks for the info, Keith. Yes, I'm the one who had the prop strike. I had the crank magnafluxed with no damage noted. I was never told to replace the camshaft as well. I'm replacing the cylinders and pistons (bought a new Maule jug kit), as well as new heads/valves from Sonex. I'm reusing the connecting rodsI don't know the order they fit on the crank, so you're suggesting putting them in any order and use plastigauge to measure clearances. I will do that. Thanks, again.
Ken
Users browsing this forum: No registered users and 59 guests
