jwd3ca wrote:OK, let me start by saying that OF COURSE I'll be using recommended oil. I really don't think that there is much science behind suggesting that an engine can be ruined in less than an hour of sub-1200 rpm by using Quaker State multi-grade automotive oil. I absolutely get it that a higher zinc content is desirable, but please... an hour of Quaker State is not going to trash my cam and/or lifters, anecdotal accounts aside. But rest assured, the next engine start will be with a sump full of 20W50 Valvoline VR-1.
And yes, I will be installing an oil cooler. Just unnecessary in this cooler Canadian climate right this very minute. But eventually.
I will take a look at the rear relief valve. As for 'something is most likely blocked', it would be enlightening to know where on the oil galley map a blockage might cause excessive pressure at the two places I have monitored: the front galley, and the top oil cooler block-off plate. Hmmm...
Thanks for the input!
Users browsing this forum: No registered users and 90 guests
