tom.corso wrote:It starts easily, takes throttle well and gives me about 3100 rpm WOT at runup. I think I have a 2.5 needle installed. At idle and low rpm taxiing I get a substantial rpm increase and smoother running with the mixture almost all the way to cutoff. Idle is a bit rough and under 800 rpm. When leaned it increases to around 900 to 950. In flight at cruise I lean to about 1/2 way out and gain about 100 rpm. I take off and climb at full rich - BUT - if I remain at full power (beyond about 500 ft AGL) the exhaust temps will go above 1450 and set off the alarm on my GR EIS. Cylinder head temps stay below 375. I am in So Wisconsin field elev 850' MSL. Both my top and bottom spark plugs have quite a bit of black carbon on them. No significant difference top or bottom. They are gapped correctly .018 top and .032 bottom. The engine is set up for 8 to 1 compression ratio and I have been running strictly 100LL....................My assessment is that I am running rich most of the time but not rich enough to keep the EGTs below 1400.
