Buying Used
Buying Used
Postby GraemeSmith » Sat Sep 25, 2021 7:31 am
Kitplanes Magazine's Kate O'Conner's take on buying a used Sonex:
https://www.kitplanes.com/buying-used-sonex-waiex/
Re: Buying Used
Postby Bryan Cotton » Sat Sep 25, 2021 9:29 am
From the article:
Similarly, the aircraft’s gross weight should be below 1150 pounds if equipped with an engine producing 100 hp or greater or 1100 pounds if the installed engine produces less than 100 hp. A Sonex with a licensed gross weight above those thresholds will be disqualified from the Light Sport category.
Is the second sentence actually true? That would imply that too low of a power loading would disqualify an aircraft from being an LSA. That doesn't make sense.
Re: Buying Used
Postby tx_swordguy » Sat Sep 25, 2021 9:59 am
Everything I have read on light sport category lists 1320lb MTOW and I believe 1420 allowing for floats on a seaplane. Outside of that you have speed requirements both upper and lower (stall). I have never seen anything listing an engine size or hp rating in the wording. In other words you could put a 5000 hp engine in a plane that met the above reqs and it would still be LSA. Likewise if you put a 15 hp engine in the same plane it would also be LSA. In this instance we could take an 80hp sonex and list it at 1320 MTOW and it would still be LSA. It would be way out of the design parameters set forth by Sonex, but it would still fit the regs. I would hate to test that set up though. We all know there are limits to what will fit within those reqs and actually work and be safe. I could be wrong about this but that has been the information I have found in the past so unless something has changed I would expect it to still be current. There is some talk about the weight limit going up on LSA but I have not seen anything yet.
Mark WHiddon
Mark Whiddon
T25 Aero Estates
Sonex N889AP
jabiru 3300 solid lifter
tx_swordguy
Re: Buying Used
Postby XenosN42 » Sat Sep 25, 2021 11:48 am
GraemeSmith wrote:Kitplanes Magazine's Kate O'Conner's take on buying a used Sonex:
Unfortunate that the Xenos or OneX aren't mentioned at all. Almost like they don't exist.
-- Michael
OneX N169XE
XenosN42
Re: Buying Used
Postby Scott Todd » Sat Sep 25, 2021 2:04 pm
One of the things that moves an airplane out of LSA is the stall speed. The FAA uses math to check this. So a stock Sonex that is certified heavier may not meet the LSA stall speed. Its just math ;)
For example, the Onex needs the full length wing tips to meet the stall requirements at gross weight. If the FAA sees the standard gross of 950 and it has the short wingtips, they automatically know its NOT LSA compliant.
Scott Todd
Re: Buying Used
Postby radfordc » Sat Sep 25, 2021 4:30 pm
Bryan Cotton wrote:From the article:
Sonex has always said that the gross weight should be based on engine power as a matter of safety.
The only criteria for LSA compliance is gross weight, stall speed, and top speed at max continuous power. The author is incorrect.
Re: Buying Used
Postby GraemeSmith » Sun Sep 26, 2021 7:40 am
I seem to recall that there is an issue of wing loading per horsepower that the factory posted about that is part of the LSA standard. It was in a discussion about why a 1,200lb "apparently legal" Sonex LSA is perhaps not if it only has 80hp up front. Wish I could find that post again. It was either a "legality" or a "consideration".
Re: Buying Used
Postby Scott Todd » Sun Sep 26, 2021 11:17 am
Like radfordc says, light Sport Aircraft fit very specific requirements. A 1200 pound "apparently legal" LSA may not fit one of the criteria such as stall speed. Power loading has nothing to do with it.
Scott Todd
Re: Buying Used
Postby Skippydiesel » Sun Sep 26, 2021 7:20 pm
Gentlemen - remember you are not just communicating with aviators in the USA.
Other jurisdictions have very different views/laws on what constitutes a light sport aircraft (note the lack of capitals).
For example: There is no air speed restriction on such aircraft in Australia (registered under Recreational Aircraft Australia/RAA , with general aviation /GA has different rule again) - just a max take off weight (600kg) Stall 45 knots, Max 2 persons, etc etc . There are other rules and some minor exception but this is pretty much the core.
Skippydiesel
Re: Buying Used
Postby GordonTurner » Sun Sep 26, 2021 10:59 pm
Hi Graeme
Haven’t found the post either, but I remember it from pretty far back. LSA rules stipulate MGTOW, maximum gross stall speed (which I seem to recall is in clean configuration), and max indicated airspeed at sea level.
The factory added reasons why gross weight should not be increased. These included power loading, structural loading, structural fatigue, and perhaps more.
Return to Second Owner Issues
