Hi Guys,
I've reinstalled the modified induction system. Since I was still waiting on the pipes I decided to mock up the fuel system.
Since I don't like the idea of pumping 10 to 20 gallons of fuel per hour through the cockpit, I'm basing my fuel system on what Peter Henry presented with some minor modifications.
The front of the mock up:
The back of the mock up:
Since I couldn't find a 40 micron screen for the gascolator I caved and bought a 40 micron filter. That's it on the back of the mock up. And, since I had a 40 micron filter, I decided to plumb it before the gascolator and remove the screen from the gascolator. With that done, what was a gascolator is now just a fuel distribution manifold. After staring at my blue manifold for a while what it started to look like a pretty cool manifold with a built in miniature vented surge tank. So, that's how I plumbed it. The cheap temperature gauge, plumbed where the AeroInjector will eventually get it's fuel, was pretty useless.
I plumbed all of the low pressure lines with clear vinyl so I could watch it work. I turned the fuel on at the tank and the lines filled pretty much like you would expect with the surge tank vent filling to fuel level much like a sight gauge.
So, I applied power.
First surprise, my 3 Amp bench supply went into current limit trying to drive my 2.5 amp fuel pump. Latter measurements showed that the pump consumes 3.5 amps in the configuration shown.
OK, substitute a 10 Amp, 12V power supply and a current meter for the bench supply. Power on and away it went.
Second surprise, the fuel pressure regulator started making vapor almost immediately. The vapor beneath the regulator outlet continued to build until if spanned the length of the connection between the regulator and the blue manifold input. It doesn't show up in pictures very well but here is an attempt.
Every now and then the surge tank vent would just burp a bubble.
And no surprise, there was never any vapor at the fuel pump input.
I feel pretty good about that setup. I was hoping I wouldn't have to plumb anything back through the firewall but I think I'll have more confidence in the system if it can release vapor without passing it through the fuel pump.
After about 20 min. of continuous operation the fuel pump was too hot to hold your hand on it for over 5 seconds. The gold manifold was just a little less hot. I didn't expect it to take that long to heat up.
It might be better to move the 40 micron filter to the bottom fuel outlet. That way switching to the AeroInjector would also serve as an emergency fuel filter bypass. We'll see.
Wes
