Hi Guys,
Quick update on the VeeCU project. Moving along at a glacial pace.
I received my PCB. We'll call it PCBs for preschoolers. There was only one trace missing :-) I assembled it and it passed a static check on the bench. Next I'll have to hook up the sensors to the engine and see them work with the engine running.
Here is a pic of some of the bits and pieces that have been collected so far:
I'm going to copy Peter Henry's fuel distribution scheme. During testing the fuel sump will be replaced with a temperature sensor so I can see how quickly (or not) the fuel pump heats up the fuel.
After a rather lengthy search I found the mating connector for the fuel injector and an affordable crimp tool here:
http://www.cycleterminal.com/index.htmlI couldn't very well start soldering and such on my Wife's built-ins so I had to clean out a space in the shop. The office has never been used as an office. It turned into a place where discarded items go to die. So, I had to clean it up and give it a fresh coat of paint. Amazingly enough the air conditioner still works.
I don't want to have to worry every time I fire up the test engine so I installed concrete anchors and bolted the Sonerai to the shop floor.
I need a portal into the ECU during development. So, I took time out to get the CAN interface and display up on what will serve as the control head during development. The CAN peripheral has been updated to support CAN FD (which I don't need or want) so it took much longer than I thought it would since I had to learn how to make the new peripheral support "Classic Can".
I can page through any number of displays with the blue button.
I'm going to retrieve my build table from Olney, set it up next to the Sonerai, and build an instrument panel on it. I'll extend the engine controls and sensor signals so I can watch everything without poking my head into the cockpit. I'm going to mount the fuel system to the table as well. I'll run both the low pressure and high pressure fuel sources from the table to the Sonerai.
The engine hasn't been run in about two years. The left front cylinder exhaust valve is leaking badly. But, I'm not going to worry about that just yet. I'll just change the oil, torque the prop, and see if I can get an engine start running on the carb. That will allow me to hook up sensors and scope the inputs and outputs of the input signal conditioning circuitry and see how well that works.
Forever Forward,
Wes
