I screwed up one of the pictures - the oil cooler bolt picture is another one of the valve cover safety wire. Unfortunately with lessons learned, both original posts and edits have to be approved by a moderator to keep the fluff out of this category, so it's hard to go back and edit. I'll be using the preview button more frequently here.
Here is another safety I added, and was the catalyst for this submission to lessons learned. My inboard wheel pant screws go into nutplates, which provide locking. There is a 10-32 hole tapped in the end of the axle for the outboard wheel pant retention, and I kept losing them. Loctite was tried and that didn't work. So I made a little washer, drilled a little hole near the edge, bent it up, and riveted it on. This gave me a safety wire point for a hex bolt rather than a low-drag phillips screw.
![Image](http://www.sonexbuilders.net/download/file.php?id=4419&mode=view)
