Securing your oil filter
A repository of lessons learned from builders with technical guidance and best practices. This is a project of the Sonex Builders and Pilots Foundation.
Forum rules
Lessons-learned submissions follow a standardized format designed to identify the issue, draw out the relevant factors and present useful guidance to others facing a similar situation. The submitter answers the following 5 questions:
1) What went wrong (or right), and why?
2) What were the shortcomings, and why did they exist?
3) What actions were taken to fix the problem?
4) What preventive actions should be taken into account for future efforts?
5) What overall recommendations should be made for future projects?
The length of the write-up and amount of detail presented are left up to each individual. Some lessons learned can be perfectly conveyed in a few simple sentences, while others will require much more. The goal is to be as clear and succinct as possible, not to generate literary masterpieces!
All posts submitted to this forum are held in a review queue for approval by a moderator. Information in the posts will be reviewed, vetted, and modified as needed before going public. Additionally, any replies that are submitted would also be reviewed to ensure they add value and remain on topic. This will avoid normal threat drift of general discussions.
Postby WaiexN143NM » Fri Jul 17, 2020 2:50 pm
Hi all,
Just a reminder, was reading on the zenith site, one member had a 750 stol with a UL350 engine. uses an automotive type filter. He claims he torqued it down to specs , but it came loose, oil drained, landed on rwy, but engine was shot and needed a rebuild. champion filters for cont/lyc have a tab welded with hole to safety wire. We can easily do this on an automotive filter with a ss band clamp,and safety wire.. also good to mark with a paint line when secured in position.
fly safe!!
Re: Securing your oil filter
Postby DCASonex » Sat Jul 18, 2020 8:24 am
Just a cautionary note to those with Jabiru engines. K&N makes a filter that has a hex spot welded on the end like some "real aircraft engine" filters, has good high flow rating and a thicker case for high pressure. Looks ideal, but beware, I have had two of those crack at the spot welds holding on the hex on the end. one resulted in total oil loss. Found out later that these have been known to have this type of failure in Jabiru engines for a few years before mine failed. Have seen this filter coming from two different countries with very different internal structure but same spot welded hex. Avoid these.
Postby sonex1374 » Sun Jul 26, 2020 8:26 pm
David A.'s experience with failed K&N filters has happened to others as well (at least 2-3 others have posted here about that exact failure). By contrast, other oil filters seldom fail unless there has been some damage done to the filter casing, such as a ding or dent in the case when installing.
The take away here is that the filter on a Jabiru engine sees some pretty demanding conditions, and should be treated with caution and respect. Any filter with even slight deformation or damage should not be used. If a securing device is used on the filter you need to be careful using it so as to not inadvertently cause hidden stress or damage to the case.
The following threads from 2011 have some additional information as well:
http://www.sonexbuilders.net/viewtopic.php?f=8&t=3226
http://forums.matronics.com/viewtopic.php?p=263252
Jeff
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Postby LarryEWaiex121 » Wed Aug 12, 2020 6:18 pm
Personally, I would be hard pressed to "attach" anything to the filter casing for fear of causing a stress point.
Since I started flying my Waiex in 2011, I've only used the NAPA Gold 1394 filter and screw it on by hand about as reasonably tight as I can get it by hand.
I oil the rubber ring and I've never had an issue with deformation or leaking of any kind. For this reason, I see zero reason to experiment with anything else.
Crossing over the 800 hour mark now on my airframe and doing well. About 458 hrs on a Jabiru3300 solid and now the remaining hours on a Camit 3300 solid.
The Camit has run exclusively on Aero Shell 100Plus since install. No issues.
Larry
Waiex121YX
LarryEWaiex121
Postby NWade » Thu Aug 13, 2020 1:37 am
LarryEWaiex121 wrote:Personally, I would be hard pressed to "attach" anything to the filter casing for fear of causing a stress point.
There's a very simple way to achieve this without creating a stress point. All it takes is a large-diameter worm-gear hose clamp.
This is one of those cases where a picture is worth a thousand words
Motorcycle guys do it all the time in addition to airplane folks, and its covered on Page 56 of the AeroVee Turbo Instruction Manual (for those folks building an AeroVee).
Enjoy,
--Noel
Return to Lessons Learned
