Condition Inspection - Post your tips and checklists here
A repository of lessons learned from builders with technical guidance and best practices. This is a project of the Sonex Builders and Pilots Foundation.
Forum rules
Lessons-learned submissions follow a standardized format designed to identify the issue, draw out the relevant factors and present useful guidance to others facing a similar situation. The submitter answers the following 5 questions:
1) What went wrong (or right), and why?
2) What were the shortcomings, and why did they exist?
3) What actions were taken to fix the problem?
4) What preventive actions should be taken into account for future efforts?
5) What overall recommendations should be made for future projects?
The length of the write-up and amount of detail presented are left up to each individual. Some lessons learned can be perfectly conveyed in a few simple sentences, while others will require much more. The goal is to be as clear and succinct as possible, not to generate literary masterpieces!
All posts submitted to this forum are held in a review queue for approval by a moderator. Information in the posts will be reviewed, vetted, and modified as needed before going public. Additionally, any replies that are submitted would also be reviewed to ensure they add value and remain on topic. This will avoid normal threat drift of general discussions.
Postby sonex1374 » Sun Jun 07, 2020 4:04 pm
The condition inspection is an opportunity to look over the airplane and its systems and find any problems that might be developing. We can support Sonex pilots and maintainers by consolidating useful references to assist with the inspection. Post your hints, tips and checklists here.
Appendix D to Part 43, 14 CFR: https://www.ecfr.gov/cgi-bin/text-idx?node=pt14.1.43#ap14.1.43_117.d
- FAA regulatory guidance on the scope of required inspections during an annual inspection. Most experimental amateur-built aircraft have operating limitations that required following this guidance.
Generic Sonex-specific Condition Inspection Checklist:
Sample_Sonex_Condition_Inspection_Checklist.doc
(154.5 KiB) Downloaded 500 times
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Re: Condition Inspection - Post your tips and checklists her
Postby sonex1374 » Sun Jun 07, 2020 4:13 pm
I collected some thoughts on AeroVee engine maintenance, originally published in a Sonex Builders and Pilots Foundation Newsletter.
Sonex Builders and Pilots Foundation April 2019 Newsletter
http://sonexbuilders.net/shoptalk/april2019.pdf
Jeff Shultz
Kansas City, MO
sonex1374
Postby mike.smith » Sun Jun 07, 2020 5:34 pm
Return to Lessons Learned
