by builderflyer » Thu May 07, 2020 5:23 pm
One more factor not mentioned is to not use the ACS gascolator (#10580) in your fuel delivery system. On the first test flight of my Sonex, now 15 years ago, during a sustained climb, my 3300 engine more than burped........it coughed. That is to say, the engine "died" for a second before continuing on. All of the measures to prevent vapor lock had been accomplished, including building a shroud around the gascolator to which a cold air blast tube was attached. The engine continued to cough once or twice during any sustained climb.
In discussing this matter with the Sonex factory, Kerry indicated that other builders had used the Usher gascolator with apparent success. So, ultimately I switched to the blue Usher gascolator and the "cough" went away, never to return. I never learned what was unique regarding the ACS gascolator to cause the cough or what is unique regarding the Usher gascolator to not cause a cough. Both have similarly sized screens. I had attempted to polish the ports of the ACS gascolator to reduce the pressure drop through it, but this was of no help.
Art,,,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,,Jabiru 3300 #261
