Submitting a Lessons-learned: Read this first!
A repository of lessons learned from builders with technical guidance and best practices. This is a project of the Sonex Builders and Pilots Foundation.
Forum rules
Lessons-learned submissions follow a standardized format designed to identify the issue, draw out the relevant factors and present useful guidance to others facing a similar situation. The submitter answers the following 5 questions:
1) What went wrong (or right), and why?
2) What were the shortcomings, and why did they exist?
3) What actions were taken to fix the problem?
4) What preventive actions should be taken into account for future efforts?
5) What overall recommendations should be made for future projects?
The length of the write-up and amount of detail presented are left up to each individual. Some lessons learned can be perfectly conveyed in a few simple sentences, while others will require much more. The goal is to be as clear and succinct as possible, not to generate literary masterpieces!
All posts submitted to this forum are held in a review queue for approval by a moderator. Information in the posts will be reviewed, vetted, and modified as needed before going public. Additionally, any replies that are submitted would also be reviewed to ensure they add value and remain on topic. This will avoid normal threat drift of general discussions.
Postby Sonex Foundation » Fri Apr 24, 2020 4:22 pm
Sharing Lessons-Learned Helps Strengthen the Sonex Builder Community
It's in our nature to strive for more, aim for better, and seek ways to improve ourselves. That's part of what defines us as humans, and this trait is ever-present in homebuilt aircraft builders. We achieve that betterment when we reflect on our successes, learn from our mistakes, and consider the examples of others.
This forum is designed to be a repository of Lessons-Learned and Best Practices. These entries are intended to transfer the knowledge gained from builders that have walked the path to those that are just starting out.
Format:
Lessons-learned submissions follow a standardized format designed to identify the issue, draw out the relevant factors and present useful guidance to others facing a similar situation. The length of each write-up and amount of detail presented are varied as needed to convey the topic. The goal is to be as clear and succinct as possible. The submitter answers the following 5 questions:
How to Submit a Lesson-Learned or Best Practice:
To submit a lesson-learned or best practice to the repository, create a short write-up using the format above. Be specific and detailed in your write-up, and include pictures as needed to illustrate the problem and solution. When you submit the post to this forum it will go into a review queue. A reviewer may reach out to you with comments or clarifications prior to approving the post for inclusion. Once approved, it will be publicly posted to the forum.
All posts is this forum are locked from replies, so general comments and further discussion should occur in the general discussion forum areas. Reviewers may need to make adjustments or corrections to the post at a later date based on user comments, but the goal is to have single posts with the right information.
Share Early, Share Often!
This is your chance to help build the body of knowledge available to the Sonex community, to bolster the efforts of builders that will follow, improve safety and our track record of performance,and to pay it forward in honor of those that have helped you. So put that hard-won knowledge to work, and share a lesson-learned!
President
President
http://www.Sonexfoundation.com
Sonex Foundation
Return to Lessons Learned
