AeroConversions Throttle Quadrant
Discussions for ULPower engines.
Postby tmritter44 » Sun Jun 30, 2024 7:54 pm
AeroConversions throttle quadrants provided by Sonex do not have enough cable pull length for UL350 engines. Initial trials on my Sonex-B are about 1/2" short. Has anyone devised a solution?
tmritter44
Re: AeroConversions Throttle Quadrant
Postby Murray Parr » Mon Jul 01, 2024 4:53 pm
I made the throttle lever longer and fixed the cable higher up on the lever so I could get the minimum 68mm throw required for the rotax, the co pilot side also seems to have no limit so copying that might also produce some ideas.
Murray Parr
WXB0015
Rotax 912ULS
MGL Explorer Lite
First flight May 6/23
RV9 builder (Sold)
Murray Parr
Postby tmritter44 » Fri Jul 05, 2024 10:56 am
I followed Murray's suggestion with good results. Moving pivot point for the throttle lever down & aft 7/16" added 3/4" of cable pull. Then attached push/pull cable to top of lever to reverse the action.
IMG_1220.pdf
Modified Aeroconversions throttle
(206.61 KiB) Downloaded 82 times
tmritter44
Return to ULPower
