UL Power UL260iSA
Discussions for ULPower engines.
UL Power UL260iSA
Postby Andy Walker » Thu Jul 07, 2011 12:04 pm
Here's another potential alternative engine for the Sonex/Waiex/Xenos, the UL Power UL260iSA:
http://www.ulpower.com/engines/ul260iSA/index.html
It's a real aircraft engine with dual ignition, air cooling, and a horizontally opposed design with oil pickup designed with ability to fly inverted. 107hp continuous at 3300rpm at a weight of 160-165lb puts it right in the Jabiru 3300 ballpark. Here are some of the factory features of the UL Power engines:
Modern Technology 4 stroke, air cooled, 4 cylinder opposed engine
Dual (redundant) electronic spark ignition (variable timing)
Multipoint electronic fuel injection with automatic altitude and temperature compensation
Electronic RPM limiter
Direct propeller drive
Wet sump forced lubrication with integrated pressure regulator
5 bearing crankshaft with thrust ball bearing
Ram air cooled cylinders and cylinder heads
High fuel efficiency
No carburettor icing problems
Excellent power to weight ratio
Electric fuel pump and pressure regulator to eliminate vapor lock and facilitate starting even under adverse conditions
I have not looked at the dimensions relative to the existing Sonex/Waiex/Xenos engines, so I'm not sure how well the current cowls might work. But this looks like a contender on paper. The only downside is at current exchange rates the price comes to about $23,600, which makes it a LOT more expensive than a Jab 3300.
Andy Walker
Re: UL Power UL260iSA
Postby uteboy » Thu Jul 07, 2011 3:51 pm
Here an interesting article on that engine when installed in a Twister.
http://www.lightaircraftassociation.co. ... le_mar.pdf
uteboy
Postby Mike53 » Thu Jul 07, 2011 6:54 pm
Great writeup and though it would obviously fit quit nicely on the Onex, as Andy pointed out the price is out of my league. :(
Antoine de Saint-Exupery
Mike53
Postby sonex892 » Thu Jul 07, 2011 11:04 pm
John Davis of American Sonex assoc fame installed one of these in his Sonex. Should be able to find photos of the cowl and install etc on their website. On a not so good note, I read somewhere he did crash his Sonex with this engine and has since repaired the plane and re engined again with a jab3300. I dont know the details of the crash
sonex892
Postby Mike53 » Thu Jul 07, 2011 11:36 pm
Mike53
Postby Andy Walker » Fri Jul 08, 2011 10:33 am
Hmm...that seems like builder error (ECU on wrong side of firewall, got too hot).
I didn't like that half that Twister article is devoted to bashing the Jabiru motors.
Andy Walker
Postby uteboy » Fri Jul 08, 2011 3:26 pm
Yes, sounds like some history there....probably something to do with cricket.
uteboy
Postby Mike53 » Mon Apr 09, 2012 11:02 am
Andy Walker wrote:Here's another potential alternative engine for the Sonex/Waiex/Xenos, the UL Power UL260iSA:
I paid a visit to UL Power and was pleasantly surprised to find the prices of the UL260iS right about the same as the Jab 3300 and the 97HP UL260i came in at $17290 us as of feb./12.
So all I need to do is convince my wife that for a measley $10000 more I can add 17HP to my Onex :Dhttp://www.ulpower.net/prices-us.html
Mike53
Postby kmacht » Mon Apr 09, 2012 8:28 pm
So if it is about the same price as a 3300 whats the advantage? Isn't the 3300 120hp vs 97hp for the UL? What am I missing?
Postby Mike53 » Tue Apr 10, 2012 11:42 am
kmacht wrote:So if it is about the same price as a 3300 whats the advantage? Isn't the 3300 120hp vs 97hp for the UL? What am I missing?
My bad.The UL engine for comparison is the UL350i at 118hp.
Jab3300-----$19,900 180lbs add the liquid cooling jacket for an additional $3500 + weight penalty? aprox. for a total $23,400
UL350i----- $22,150 172.8 lbs,Full FADEC
Bottom line the Jab without the cooling jacket comes in @$2250 less .For myself I would choose the UL power for my Onex.If I could afford the Jab I would find the extra $2250 to buy the UL as in my opinion when you compare them totally the UL comes out ahead.
I will watch the Euro closely as the price could go down farther yet what with all the problems it is having right now.
Mike53
Return to ULPower
