Here is a copy of what I just put on the Sonex Facebook page.
After 9 months of tinkering improvements, The Waiex is flying again with much improved cooling and other mods. Only a 40-minute flight but everything is seemingly improved. Proper testing to follow to see if any performance gains.
https://youtu.be/jurXW_zx-P4Love the sound of my new dual custom-made exhaust and the back pressure tests are well within specs, could possibly use larger openings on the perforated tubing inside the mufflers but probably won't bother with my plane, might be tempting to start producing them.
https://youtu.be/6Nwr4A6TbhUHaven't flown her since last April and came in a bit hot with the speed and skipped along the runway a bit after floating well past my landing target.
- Bit of an ugly duckling but still have to do cosmetics and paint after I am happy with testing the new engine thrust line angles.
- Very close fit and it is slightly rubbing between 9 O'clock and 11 O'clock positions facing the prop. That rubbing would be on decent under no power, basically an air brake being pushed towards the cowl. Well, that's my theory anyway...
- The new cooling plenum works awesomely.
