Finally got to the testing stage!
Density altitude of 3500' and 5650 RPM WOT produced 2Psi of exhaust back pressure. Rotax specified limit is 2.5Psi
I could trim the ejector nozzle a bit which should give slightly less back pressure but maybe not worth it and I am also worried about loosing a milli knot of speed if I do that....
- IMG_7139.jpg (83.33 KiB) Viewed 241 times
I put the ejector/tail pipe in the press and made it oval shape for more clearance, probably need a bit more under the nozzles but so far no burn or rub marks appearing.
- IMG_7137.jpg (139.04 KiB) Viewed 241 times
- IMG_7136.jpg (70.59 KiB) Viewed 241 times
