Murray Parr wrote:Has anybody considered adding a degree or 2 of right thrust to the Rotax engine to help minimize out of trim conditions and if so, what methods would/have you used?
I am thinking the easiest way to adjust the thrust line would be to add a AN970 type of washer between where the gear mount attaches to the airframe. Any thoughts on this or other suggestions?
Skippydiesel wrote:Kai - I have been thinking of fitting a pilot controlled aileron trim, (to counter effect of passenger) so would very much like to have details on how you have done this.
Kai wrote:Skippydiesel wrote:Kai - I have been thinking of fitting a pilot controlled aileron trim, (to counter effect of passenger) so would very much like to have details on how you have done this.
Hmmmm.
While this system works fine for me and has been copied on one other Sonex A, I am sure there would be a lot of naysayers, as they would feel it could interfere with aileron control. If the rules Down Under are the same as here- if something is not specifically approved, it is absolutely forbidden! Anyhow, due to cracks in the aluminium sheet I need to take my seat pan out for replacement when winter sets in, I´ll then get a photo or two from the setup.
