13brv3 wrote: I'd really like to hear more about the Rotec TBI experiments. I've been considering a homebrew EFI, or a single carb setup since I really hate the dual carbs.
13brv3 wrote:I'm assuming this was with a prop that was known to have full static RPM with the stock carbs? Was is a single TBI? Pictures would be excellent.
You mentioned that you copied a known working configuration. Was it the recent webinar that mentioned an aerobatic team that used that configuration? Was that the config that you copied? I had never heard of that before.
Dual carbs is always claimed to be higher performance, but I can't believe that's universally true. With a proper size single carb/TB, and a well designed intake, I have to believe the performance would be equal. I do hope to test that theory some day. I've joked that the only thing worse than a carb is two carbs.
Rusty
Murray Parr wrote:
If you can open the attachment, this is what I copied, it was sent to me for guidance by Rotec.
I have the early sensenich prop that Sonex sells, it was never tested with the original carbs but other reports found it should be close to 5200 static. Single TBI 40 used
bishoff7 wrote:Hi .Are you making any progress with your TBI .I ask because I have have been involved in the installation and setup of Rotec TBI before
and a 40mm should pull way better than the results you are seeing.
Regards Bish
