peter anson wrote:It's blank in the handbook because you are supposed to determine some of this stuff during your test flying, but Vne and maximum flap extension speed are stipulated by Sonex. Vne is 171 knots and maximum flap extension speed is 87 knots. Must confess I've exceeded that one quite a few times after take off.
13brv3 wrote:I certainly get that you're required to determine the exact numbers yourself. I also know that unless you deviate from the design, or have a leak in your pitot static tubing, the numbers should be very close to the factory numbers. If they want to leave the POH blank, that's fine, but I think they should at least post the numbers for the factory plane. I would much rather have a ballpark number than nothing.
Rusty
XenosN42 wrote:Hi,
I'm unsure about one thing. Is your aircraft a Sonex or OneX? I've searched thru many of your previous posts and they refer to a OneX, but this request for POH numbers refers to a Sonex. The numbers will most likely be different.
Have you read the FAA flight test circular? It has some great advice on phase I flight testing. Even if you don't follow it exactly it will give you some ideas. For example it discusses how to estimate airspeeds, with that extra safety margin, during early flight testing. https://www.faa.gov/documentLibrary/media/Advisory_Circular/AC_90-89B.pdf
Does your aircraft have an EFIS made by MGL, Dynon, Garmin, GRT, or Advanced Flight Systems? If so consider using https://jasflyer.com/ which has some great tools to help you more easily collect the flight performance numbers you need for your POH.
You have mentioned that Sonex should publish all of their flight performance numbers. However, IMO, those numbers might be misleading. What if a builder uses a different engine? ULS? Different prop? And then there are pilots that would just use the Sonex numbers and never actually run their own flight tests to verify how their aircraft is performing.
Good luck with your flight testing. It should be a challenging but fulfilling time.
XenosN42 wrote:Hi,
