Murray Parr wrote:Congratulations, Beautiful looking plane :-)
Wondering if all your cooling systems work well?
xeriotti wrote:Murray Parr wrote:Congratulations, Beautiful looking plane :-)
Murray!!! It took me a while to get it dialed... I swapped my water radiator for a bigger, thicker and fancier one.... But the big improvments were achieved when i started playing with the intakes and outlet sizes... When i started i couldnt even run for 10 minutes on the ground without going over water temperature parameters... It took me almos 4 hours of changing things and flying to achieve perfection. now im running with OK temperatures indefinitely no matter my power setting and flying attitude... NACA inlets directly and hermetically ducted into water and oil radiators.... rear of the radiators are next to low pressure area from the cowl flaps. frontal intakes hit directly into front cylinders, top intakes deflect and hit rear cylinders and sweep hot air from air filters (ideally XD) Works great...
Skippydiesel wrote:xeriotti wrote:Murray Parr wrote:Congratulations, Beautiful looking plane :-)
Hi Xeriotti,
My Rotax HD radiator (coolant) temperatures are spot on 95C in the air - still have issues on the ground with temperatures always over 105C, as high as 120C on occasion.
My cooling problem is the oil temperature - best I can do in the air is 104C, when OAT is below 11C and I focus on keeping a very strict straight & level and MAP/RPM exactly by the book. I have the Large Oil Cooler but it just doeskin seem to do the job, when I put my CS prop in Cruise mode.
I am interested in the Extra Large Oil Cooler, now offered by Rotax - it may just be what I need to get my cruise temperatures between 90-100C
I am about to return my Sonex to my home workshop to do do several modifications - the main one being the cooling system lay out at this stage Radiator is moving from low on firewall, to front of engine and Oil cooler, from front of engine, to just in front of where the Radiator is now.
