SonexN76ET wrote:I am reworking the radiator intake to allow more airflow and will post some photos in about two weeks after i return from some travels. I will also post some photos of the exit air outlet. I am wondering in the Sonex B side outlets would be beneficial for the cooling?
Jake
Skippydiesel wrote:UPDATE!
First flight after cooling (& unrelated) mods a week ago.
Ambient 30+C on ground. 22C @ 6500ft.
60 minute flight
Oil - 72C on ground. 105C on Climb Out. 94 -97C in Cruise.
Coolant - 72C on ground. In Cruise 82C
DELIGHTED!!!!!
Brief Mod Description;Coolant Radiator - Moved from rear of cowling/under lower firewall, fed/restricting ALL exit air from cowling. Relocated to forward, under gearbox/exhaust pipes, fed with ambient air through new scoop in cowling - no sealing/ducting.
Oil Cooler - Rotax Large Cooler, moved from under gearbox, fed ducted ambient, air exiting through duct (seperate air system to cowling). Installed Rotax Extra Large in cowling exit air - no sealing/ducting.
I now expect there to be overcooling in winter - my initial plan is to modify the cowl flap, so that it will provide a restriction when closed. The restrictor will be removed for summer sorties. The restrictor may help with drag by increasing exit air velocity.
Murray Parr wrote:Skippydiesel wrote:UPDATE!
Lots of pictures please, I am hoping to plagiarize any successful design...
Skippydiesel wrote:Murray Parr wrote:Skippydiesel wrote:UPDATE!
Can email you
