Kai wrote:Yup!
I´m with you as far as the messing up things goes- high five!
From my days as an engine application engineer some exhaust system guidelines emerge:
Engines hate bends and elbows in the exhaust system-especially a tiny unit like the 912. They create back pressure which is highly undesireable. The rule of thumb is that one 90 degree 3D (the bending radius is three times the pipe diameter) creates back pressure 16 times the equivalent length of straight pipe (I am speculating you have 4D bends). Try to keep total pipe lengths and the total deviation in degrees as identical as possible for the four pipes; if the difference is too big, you are building a variation in egt´s into the system.
A roller coaster unit like a running 912 in its mounts is really jumping about all over the place. Somewhere very close to the exhaust ports you need something that can take up this movement. You also need something that can take up thermal expansion/contraction. If not you will face cracked piping.
And:
I have been leafing through my construction drawings (issues 2003!). They include building instructions for the Aerovee, Jab 22A, and Jab 33A, and are intended for use if the builder wants to weld up his own truss. They are all dead straight in all axis- no deviation whatsoever.
I tried to keep the lenghts/volumes as similar as possible... I will measure the CCs of each header maybe tomorrow to know how much its off one from each other. But im pretty confident on how it came out. its pretty close measuring the lenght, maybe +-1cm
If we consider that almost 95% of cars use unequal lenght exhaust systems and almost all of them are just logs... This will be a great upgrade.
Zack wrote:Here is my custom Rotax exhaust. The factory bed mount drove much of my design choices, I really like how you integrated the ring mount! I think that's how it should have been done from the start. I had to take a 4-2-1 approach. From Sonex's webinar, they chose a similar setup but used a Toucan exhaust without a final merge, so it's really two 2-1 exhausts with a center line exit.
Regarding my design, I used PipePRO software application to try and determine ideal collector length, but between the assumptions I needed to make for the application and the compromises I needed to make working around the mount, I'm not sure what advantages I will see. I tried to keep the collectors all equal lengths, I used stainless steel also, and I used inline motorcycle style mufflers. In fact, I hired the job to a motorcycle shop used to working with the smaller diameter pipes and fabricating custom exhausts.
What diameter collectors are you using? Will you step up diameter after the collector? Will you use an in-line muffler? I'm enjoying following your progress. Thanks Kai for contributing also.
That Zack looks great!!!... Im using 29.8mm internal diameter headers, and as a rule of thumb i should be stepping up 1.9 times that for the collector. and 0.5 times the diameter.
I will make it slip on with springs...if it sounds horrible i will set up some kind of silencer. But i have real good expectations for sound and power levels.
