Rotax Propeller
Rotax 912 series discussion.
Re: Rotax Propeller
Postby xeriotti » Tue Aug 16, 2022 5:20 pm
13brv3 wrote:Thanks for the link. I don't see how that prop isn't stalled at lower speeds.
Rusty
Maybe they are DE-Tuning the 912 performance to make the Aerovees look good? XD
xeriotti
Re: Rotax Propeller
Postby 13brv3 » Tue Aug 16, 2022 8:19 pm
xeriotti wrote:Maybe they are DE-Tuning the 912 performance to make the Aerovees look good? XD
This is the first factory Rotax that Sonex has built (with help from a hundred people <g>). Have they even flown it yet? It will be really interesting to see what they record for performance. I will predict that exhaust wrap won't be on there long. I bet I had exactly the same wrap, on the same exhaust, and it went less than 15 hrs.
Rusty
Rusty
Onex- Rotax 912 (135 hours and counting)
Fixed wing, gyroplane, A&P
13brv3
Re: Rotax Propeller
Postby garyb » Tue Aug 16, 2022 8:23 pm
xeriotti wrote:
garyb wrote:Hi
My Rotax powered Sonex has a 68 inch wooden GT propeller off a Tecnam P2008 .Static rpm is around 5100, Solo it climbs sea level at 1800 fpm at 70 kts, cruise 2500' 120 kts 5200 rpm and 5500 135 kts WOT it pulls to the red line 5800 rpm. The prop could probably do with a little more pitch.
Cheers
Gary!! Thats great info!!! Are you aware of the pitch of that propeller? If its not explicit in the model... Maybe we can decode it from your serial number. The other way is to measure the angle at 75% of the radius. But its a tricky task (much more tricky if installed on the plane!)
How fast is your level flight at 5800 WOT? And what fuel consumption are you seeign at your 120kt 5200rpm cruise?
PS: Those numbers are amazing... I think i went the right way with the 912...
Hi
I worked out the pitch to be 67.5 inches the P/N of the prop is (GT2-173-VRR-FW 101 SRTC) so I think GT don't want anyone to know the actual pitch. At WOT I cant leave it there as that's were the redline starts, its burning 4 gallons/hour in cruise.
Cheers
Sonex #1531 Rotax 912ULS. 250 hours and counting.
garyb
Re: Rotax Propeller
Postby xeriotti » Wed Aug 17, 2022 9:38 am
garyb wrote:Hi
Cheers
I ve been loking at that propeller code before, as its visible in one of the pictures of your plane... I unseccesfully tried to decode it...
-GT2 beign the brand and type maybe
-173 is diameter in centimeters
-VRR-FW maybe having something to do with pitch <----------- Any ideas???
-101 is the bolt pattern for sure, 101,6 thats 4"inches
Tried thing like this but it may be more intrincate
V + R + R = 22+18+18 = 62
FW possibly means sepparately 6 and 23 62,3?
Yes, i was really trying to find out what propeller was that XD
xeriotti
Re: Rotax Propeller
Postby Onex0029 » Fri Aug 26, 2022 9:41 am
I am installing an AEROMOMENTUM AM15 in my OneX and have decided on a 4 blade 58” Bolly prop. I know it’s not optimum length but ground clearance is an issue. Does anyone know if, and where, a person could get extended gear legs manufactured? I think 4-5 inches would be answer. I’ve already installed 5:00x5 tires.
Onex0029
Re: Rotax Propeller
Postby WesRagle » Fri Aug 26, 2022 10:51 am
Hi "Onex0029??",
Onex0029 wrote:Does anyone know if, and where, a person could get extended gear legs manufactured?
https://sonexbuilders.net/viewtopic.php?f=5&t=5456&hilit=bennett#p41272
Hint: Read forward from the linked post.
Good Luck,
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Re: Rotax Propeller
Postby Kai » Thu Sep 15, 2022 2:50 am
I fly a fp 2-blade Sensenich wooden prop on my Rotax/Legacy combo. The prop has the common conical Sonex hub intended for the scull cap spinner and came beautifully statically balanced from the manufacturer- I get 5200 rpm wot gnd sl and a shade under 5800 rpm flat out at 3500´amsl: rejoice!!
But Rotax insists you also need to dynamically balance the prop- easier said than done with the conical Sonex prop hub and the skull cap spinner: where to position the neccessary balancing weights?
I can think of only one place- the prop hub. Having said that, the balancing machine comes up with some hefty weight values, I am guessing because of the very small radius (half the prop bolt circle diameter) on which they must function. I am sure this is fine if you want your hub to look like a swiss cheese, but structural integrity has started to worry me.
Comments?
Kai
Re: Rotax Propeller
Postby sonex892. » Thu Sep 15, 2022 4:19 am
Kai wrote:But Rotax insists you also need to dynamically balance the prop- easier said than done with the conical Sonex prop hub and the skull cap spinner: where to position the neccessary balancing weights?
Comments?
Ideal time to ditch that overly heavy (3lbs) lump of aluminium with real a spinner.
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Re: Rotax Propeller
Postby tx_swordguy » Thu Sep 15, 2022 12:49 pm
I balanced my 3300 jabiru sonex and yes the heavy spinner is a pain. I have a couple of extended prop bolts that have as many as 10 washers to balance. Felt better about that than drilling out weight. My a&p asked about it the next condition but said it was fine. I did notice a difference in vibration
Mark Whiddon
T25 Aero Estates
Sonex N889AP
jabiru 3300 solid lifter
tx_swordguy
Re: Rotax Propeller
Postby Skippydiesel » Fri Sep 16, 2022 6:58 pm
tx_swordguy wrote:I balanced my 3300 jabiru sonex and yes the heavy spinner is a pain. I have a couple of extended prop bolts that have as many as 10 washers to balance. Felt better about that than drilling out weight. My a&p asked about it the next condition but said it was fine. I did notice a difference in vibration
Did you do a static balance before installing & doing the dynamic??
Skippydiesel
Return to Rotax
