by CaseyCooper » Sun Sep 19, 2021 10:49 pm
Skippydiesel,
My Rotax in my Sonex isn’t new. It was sent to my friend Ronnie who is a iRmt and teaches Rotax maintenance courses, works the Rotax booth at Airventure, and produces aftermarket big bore kits and additional components for the Rotax series so I don’t question a word he says. I ran the oil and filter for. break in/cleaning period since the engine was torn down and reassembled with new components. In that period of time I just used it as a flush procedure which he does on every engine he breaks Into just to collect the crap, then throw in new Sport 4 and a Rotax filter.
Kai,
I’m using the Aeroconversion hydraulic brakes. I’m using toe brakes I designed I’m conjunction with 1/8” brake lines with 1/2” bore master cylinders. For all my mag checks I perform them at 3,500 rpm and they hold just fine. If you’re having issues you might try a new master and/or lines and fittings to help provide better braking force.
Zack,
Mark and I at Sonex were taking about that exact issue with the sump on the iS at Airventure and the banjo was the best option. Another that I had found that might work well is at Specialty Flightlines they produce a stainless banjo with about a 30 degree bend that would work wonderfully. They produce Teflon aircraft lines for whatever application. You just send them whatever measurement you have on line length, what fittings you’d like to use, and they make up the lines for you. The nice thing is they’ll last the lifetime of the engine anyway. As far as your cowling your on the right track with a bigger spinner. Because of the torque the Rotax produces, it should have a bigger cowl opening at its disposal. Mark and I had talked about. Blister that they may offer to Rotax users to integrate into their cowling for simpler installations. And as far as the radiators, he had mentioned installing them on the side next to the vents on the B cowls and the exhaust on the bottom. Because I have a vertically split cowl (and makes a molded in scoop complicated) and have found out just how well my plane cools, I’m redesigning my scoop so it’s more aerodynamic and restricts a position of the airflow to bring the temps up. I already have a mock up that recesses my radiators in flush and all in the one scoop. I’ll be making it out of carbon fiber to increase strength and durability. I’m also working on some other aerodynamic components, airframe related, that will hopefully help refine the plane further. I’m eager to see how your install comes along! Looks like you’re right on track with some great ideas.
N7777X
Tailwheel
Rotax 912
3 blade Warp Drive
