by Kai » Mon Aug 30, 2021 4:43 pm
I’ve finally got some cruise numbers.
Airframe: Sonex Legacy #0525 standard gear dual stick, first flight may 2005; accumulated flight hours presently 605.
Engine: Edge Performance EP915ECI (Rotax 912 ULS refinement), max output 120HP/5800 rpm/29,92”Hg. A/F ratio 12.8-13.2, presently 12 hrs tt. Engine is still loosening up and rpm readings very slowly creep upwards.
Cooling: Split radiator up front, on each side of red gear housing, combined grid size as for R914. Oil cooler- the largest size Rotax suggests- installed centrally up front, below gear housing. Cooling air exits under cowling as per plans, plus side outlets.
Prop: Sensenich wood/glass 2 blade fp 64x82 with conical hub for Sonex. Standard Sonex scull cap spinner.
Note: Sensenich prop first had to be dynamically balanced. It is a true cruise prop, at climbout from home field it allows the engine to turn 5200 rpm with initially 29.92”Hg MP (remember:efi- no venturi pressure drop.) VSI then reads 1500’/min. WOT static ground home field 5050 rpm/29.92”Hg MP.
Combo weight: 309 kgs plus 40l fuel and one fat flier. CG empty at 20% aerodynamic chord (forward limit)
Note: very quiet late afternoon, little or no convection, headwind component apprx 5 kts.
Ambient field temp: 24 centigrades
Ambient field pressure: 1022 mbar.
Field elevation: 38’ (!) amsl
Track: 45 degrees magnetic
Altitude: 3000’ amsl.
1)
Rpm: 5050. Mp 22”Hg
ASI: 126 kts (gps gs 122 kts)
2)
Rpm: 5550. Mp 27”Hg (wot)
ASI: 147 kts (gps gs: 143 kts)
Note: it has been explained to me that this would translate to apprx 152 TAS at wot.
Note: I hate TV screens, so the panel only sports steam gages- brand is Aviasport. The tach, however, does not promote exact readings: too fat markings.
Note: while barely acceptable for hot (scandinavian) summer conditions, the cooling system as a whole will be outside Rotax specs during winter. As of present day, oil temp will not rise above 70C. Coolant stops at 65C. What will happen at -10C ambient, keeps me awake!
This original posting has been edited, and will be again as further numbers become available.
Kai
Kai on Thu Sep 09, 2021 3:06 am, edited 3 times in total.
