garyb wrote:bishoff7 wrote:If anyone is still interested in a mount to fit up a 912 to a standard aerovee mount I have just finished a prototype and it is a good fit under the universal cowl . it does however place the prop hub forward of where the aerovee sits by 15 mm this being unavoidable .This mount replaces the original rotax ring mount and bolts directly to the standard shock rubbers on the aerovee mount thus eliminating the need to modify anything. Any interest let me know
Regards Bish sonex 1178
Cbishoff6@bigpond.com
Hi Bish
How does the 15mm effect the cowl fitting. I am thinking of shifting mine forward about that much because the Rotax is quite light.
Cheers Gary
gcm52 wrote:Very nice! What size/type of tubing did you use? Did you move the Rotax forward at all due to it being lighter? Do you have weight and balance calculations for the Rotax position?
