Brett wrote: studying the mount options for a 912UL on a Onex, and I'll be making a custom mount pretty soon. I was planning to move the CG of the 912 4" forward of the Aerovee CG, though I know that makes the cowl a nightmare
Wow Rusty 4" ???
I moved my prop hub 1 " forward of the origional Aerovee turbo position and found the CofG ok... could maybe have gone furthur but it flies fine and weight and balance was ok...
With two heavy guys, low fuel and a little bit in the back is on the aft limit and feels a bit funky but still is ok.. I think 4" forward could be an overkill... I have no idea about the W+B on a onex but just food for thought.
13brv3 wrote:Thanks for the excellent info George, and congrats on being this close to finished. I do have a few question though.
When you say you moved the engine 7 inches forward, where are you measuring? Are you saying the 912 prop flange is 7 inches forward of the Aerovee flange?
Did you also raise the thrust line, or is it the same as the Aerovee? I have to admit that I'm tempted to raise the thrust line an inch to help with prop clearance. BTW, what diameter prop is that?
I'd love to see other pictures of the FWF installation, either on the forum, or via email if you don't mind.
Rusty
13brv3@gmail.com
Users browsing this forum: No registered users and 33 guests
