Re: Prop bolts install
Posted: Sun Sep 15, 2019 6:36 am
Murray Parr wrote:At this stage I am thinking my only option is to drill out the threads in the Rotax bushings and install AN bolts with Nord Lock washers under a Nyloc nut unless anyone has reasons not to do this or has a more successful way to do this. Keep the ideas coming as I am sure others will need this info too
I'm not familiar with the rotax prop mount but providing there is enough thread poking through for a Nyloc nut, could you not just drill out a small portion of the threaded section of the bush so the thread doesn't bottom out in the bush? Then use nyloc nuts. Nyloc nuts with no safety wire does the job on jabiru engined planes. The difference by the sound of it, is the Jabiru bushes are not threaded.
