BRS wrote:Chris,
Sounds like the exact mistake I made about a year ago. Got the nice B&C full wave regulator built for the Rotax 9xx engines. Quickly let the smoke out of my stator (at idle!). Mine is a Revmaster so the alternator is a bit different, I'm not sure how Aerovee does their stator.
I'm using the EarthX ETX680c on two planes. One of which has a 60amp alternator. It's common to see 50+ charging amps at idle but in this plane that works. It will try to do the same thing on the Aerovee, for a second or two. I've found, that on both planes, the key is to let the battery charge at idle/low-idle until the current goes down and voltage comes up. Usually takes about 4 minutes which is a non issue as the oil is still warming up and I'm going through checklists.
