B&C LR3C OV/LV regulator
Postby Darick » Wed Jan 30, 2019 8:22 pm
Is anybody using this regulator in place of the Sonex factory regulator? B&C ELECTRICAL-part number LR3C?
I'm still waiting to see if Bob Nuckolls voltage regulator that he discussed on episode 20-21 becomes available, which is supposed to be designed for the Sonex (and other similar) aircraft electrical systems.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Re: B&C LR3C OV/LV regulator
Postby gammaxy » Wed Jan 30, 2019 9:25 pm
I wouldn't think so. The manual says it is for "control and regulation of a B-type, wound-field alternator". The Aerovee uses permanent magnets instead.
Postby Darick » Wed Jan 30, 2019 9:33 pm
Thanks very much...I already made a mistake on another item I need to return.
Darick Gundy
Sonex #1646
N417DG
Darick
Return to Electrical System
