Thanks. Really? Did you measure that? I say this for two reasons, the original aerovee alternator was only 10A and the electronic ignition on the IO360 clone I had in my RV was only 1.2A.
Kevin
gammaxy wrote:The explanation for it being about 7 amps is that each coil is 4 ohms. The triggers charge each coil and reach a steady state current of about 13v/4ohm = 3.2 amps across each one. My first two coils failed around 200 hours after becoming 2 ohms and drawing double the current.
