MGL RDAC alternator pick up for AeroVee
Postby rhw5548 » Wed Jun 14, 2017 12:30 pm
Hi Guys, looking for information on how to wire the "CURR" on my MGL RDAC. This would be current flow to the Battery.
I see the middle post from the regulator goes to the Battery, is this also used for the Current on the RDAC. Do I need a current
sensor from MGL? are there others, are different options?
rhw5548
Re: MGL RDAC alternator pick up for AeroVee
Postby peter anson » Wed Jun 14, 2017 2:09 pm
According to the manual you need a current sensor from MGL which has its own set-up manual.
Postby mike.smith » Thu Jun 15, 2017 8:44 pm
peter anson wrote:According to the manual you need a current sensor from MGL which has its own set-up manual.
Yes, and I've never gotten mine to work right. I finally gave up. Too many variables (it's not fire-and-forget). I just look at the "volts" on the MGL screen and can see if it's charging or not.
Postby rhw5548 » Thu Jun 15, 2017 10:09 pm
Thanks Mike
Plans Built SN #0243
MGL EFIS Electronics
Tri-Gear, Dual Controls
Todd's Canopy
Prince p-Tip Prop
Echo UAT (ASDB)
Jab 3300 A
FlyQ EFB
rhw5548
Return to Electrical System
