capacitor which one
capacitor which one
Postby dynomike » Thu May 04, 2017 10:54 pm
Adding a capacitor and don't know which one to order .I have a 3300 jab
dynomike
Re: capacitor which one
Postby vwglenn » Fri May 05, 2017 9:44 am
Flux.
Sorry couldn't resist.
Glenn
Sonex #600
N889AP
vwglenn
Postby Bryan Cotton » Fri May 05, 2017 10:07 am
Dynomike,
What are you capacitating? I am not adding any caps to my Waiex so I'm not sure where this is needed. The voltage rating of the capacitor should be in excess of what it sees, otherwise I'd say it is not super important.
Postby andrewp » Fri May 05, 2017 12:27 pm
Good rule of thumb: double or more of the voltage you are smoothing.
andrewp
Postby sonex1374 » Fri May 05, 2017 3:30 pm
These capacitors from B&C are probably the most commonly used ones. They are 22,000 uF, 40 Volt (but anything over 25 Volt is OK).
http://www.bandc.aero/electrolyticfilte ... tor-1.aspx
Jeff
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Postby dynomike » Fri May 05, 2017 6:18 pm
Great .thanks so much for the answer .
dynomike
Postby n502pd » Sun May 14, 2017 10:46 pm
sonex1374 wrote:These capacitors from B&C are probably the most commonly used ones. They are 22,000 uF, 40 Volt (but anything over 25 Volt is OK).
Jeff
Just returned to site and wished to add a few notes about these large caps some are using.
1) check the temperture ratings. It may be hotter than one would think under the tank and pannel after shutdown, or on hot days.
2) At the very least double, or tripple the voltage rating. Caps will absorb spikes on the dc line, and if the spikes are really over the voltage limit, the cap may fail unexpectedly at a later time, either shorting and venting its guts into the cockpit, or opening fuses somewhere.
3) There are also altitude specs on them. The spec may be 10,000 feet, but there are `14K+ hills in the US!
4) On condition inspections, if you are using a cap to reduce/elliminate dc buss noise, be sure to check the little button( may be colored red, white, or black) on top of the cap near the terminals. It is the vent plug, it can weep or be distended when the cap has had some sort of trauma causing the internal pressure to increase. Handle with care if yours shows these signs as it may be just like a rotten egg..touch it haphazardly and you may be covered with some nasty stuff. Dont ask how I know about eggs!
5) These types of caps do age and their effectiveness can deminish with time, especially when in hot conditions.
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
n502pd
Return to Electrical System
