Alternator/regulator electrical question
Posted: Tue Sep 22, 2015 8:29 pm
I have a permanent magnet alternator & voltage regulator on my VW engine very similar to the one on the AeroVee.
I also use a S704 relay on the DC output of my regulator to be able to cut it off from the rest of circuit if needed.
The alternator stator has an AC output (2 wires) that goes directly to the regulator and I tap off that to get an RPM reading. (See my other thread here: viewtopic.php?f=6&t=2294)
The strange thing is, when disconnect my alternator/regulator (with the S704 relay), I also lose my RPM reading, as if the whole alternator is turned off.
This in itself is not a problem but I just don’t understand why this is, how can cutting off the output from the voltage regulator/rectifier from the circuit render my alternator inoperative?
It’s not shorting the alternator is it?
Please note as mentioned in the other thread, I am currently using an optocoupler to “square” the signal coming from the alternator to pick up my RPM,
but before I was just getting the signal directly off one of the output wires trying to read the pigtails from the signal (which had its problems), I had the same behaviour back then losing all readings when the relay was turned off.
Do others get RPM readings when the alt relay is switched off?
If so can anybody enlighten me into how this works as my knowledge in this field is limited.
