MGL RDAC
Posted: Thu Apr 02, 2015 7:22 am
The MGL RDAC has printed on it that it must be protected from engine fluids, heat, moisture, excessive vibration etc.
I asked the UK dealer for MGL (Paul Sistern of Parts4Aircraft) how he would suggest we do that, given that the RDAC has to be on the engine side of the firewall. He suggested mounting it in a moulded plastic food storage box. In Tesco (a large UK Supermarket) I have found a 900 ml food storage box which says on it that it tolerates -20 degrees C to +120 degrees C. I am thinking about mounting the RDAC on the lid of this, on the firewall, so as to act as a kind of shock absorber, and then fit the base of it as a removable cover, using the flaps on the lid to retain it. Of course I will have to cut various holes in the base to take the various sensors to the RDAC, so it will no longer be air- and fluid-tight, but it should be better protected than if there were no such cover.
Has anyone tried anything similar? If not, what other precautions have you taken to protect the RDAC from engine fluids, heat, moisture and vibration? Or has it been your experience that the MGL RDAC is so robust that it doesn't require any special protection?
Tim Mobbs
Sonex #1555 Aerovee #0672
Bungay, Suffolk, England
Tim Mobbs
