OK ... I am aware that this topic might open up a can of worms and that is NOT my intent at all. I would like to begin a logical discussion about the merits of dual ignition vs single ignition or a system somewhere between the two. It's correct to say that dual ignition systems are safer but are they really? I had an experience on my Aerovee many years ago where I fouled both plugs on one cylinder. Needless to say the fault was with me but to say that two ignitions guarantee that cylinders will always fire is not accurate.
Some builders are using single ignition set ups on their VW conversions with some success. I have read (and tend to believe) that the initial reason for dual ignitions was that mags weren't that reliable back in the day, the cylinders were quite large requiring dual sparks to properly ignite the mixture, and that because of low voltage coils small plug gaps were used that were prone to being fouled by the lead in the fuel.
Todays modern electronic ignition systems are extremely reliable, ignitions coils can produce an amazingly hotter spark allowing for larger plug gaps, and many are now using unleaded Mogas so plugs fouling is greatly reduced.
The Corvair uses a semi-dual ignition system in that there are two trigger sources (electronic/points, dual points, or dual electronic) which drive two separate high voltage coils that are then sent through an automatic coil selector unit. Admittedly it is single ignition after the distributor cap with one wire & plug per cylinder but these systems have proven to be very robust. I have never fouled a plug in my Corvair flight engine. I now use iridium plugs but used standard spark plugs for a number of years prior to that.
This system is electrically dependent but so is every engine that uses electronic ignition, electronic fuel injection, or requires a fuel pump that runs full time. A good alternator and battery are a redundant system for power as long as the pilot has a warning whenever the alternator goes off-line or battery/system voltage drops.
The reason this comes to mind is seeing the threads concerning the second plug holes in the VW heads and the concerns that come with that along with some complaining of the noise created by the B&S magnetrons.
Would it be possible to place four hall effect sensors instead of two in the rear flywheel area and time them so that you would have dual electronic ignition sources and feed those into four dual wire high output coils? This would eliminate the magnetrons and add two more electronic ignition coils. Of course this would still require dual plugs. The other option would be to drive a dual ignition system from a low profile distributor cap/rotor system similar to the Corvair set up?
There may be many ways to approach this so I'd be interested to know if anyone has considered this and what approach seems reasonable from another view point. BTW ... my '74 Beetle with single ignition and a weak spark points system has yet to foul a spark plug.
Any discussion? Have I lost my mind?
Dale Williams
N319WF @ 6J2
Myunn - "daughter of Cleanex"
120 HP - 3.0 Corvair
Tail Wheel - Center Stick
166.7 hours / Status - Flying
Latest Video:
https://www.youtube.com/watch?v=1VP7UYEqQ-g
