approx 23v to 27v AC at 3000 RPM when measuring across the alternator leads by themselves disconnected from the regulator.
gregsonex wrote:I used a multimeter to first check output from alternator wire to VR and it shows ~14 volts(I’m going to retest this on AC setting). I then checked output from voltage regulator and it only shows ~2 volts. I have a spare voltage regulator but it showed the same output. A friend suggested running a resistance test on either of the two wires from alternator to VR and it should be ~100ohms. Does this sound correct?
Bryan Cotton wrote:We shut off the secondary at the top of the climb. About 5 minutes after I turn off the secondary I check the voltage and it is generally 14.6. The secondary takes a lot of juice and the battery needs to recharge after the start. First flight should probably be 30 minutes if things are going well. That will let you evaluate your charging system.
