Darick wrote:I feel stupid asking this but...
I'm in the process of hooking up the primary ignition switch with shielded wire. Center wire goes to switch terminal using spade crimp-on connector (nothing new here it's just like all the other switches), other end goes to the P lead.
I don't know how to handle the shield wire the best way...connect it to my "forest of tabs" which is located on the inside firewall? I know only one end is to be connected.
If yes, does anyone know if a picture or video exists showing a good technique for attaching the braided shield to a connector? Then what? You would have to extend that connector to the "forest of tabs" with another wire. Seems messy and not very elegant...not that wiring is elegant but I'm a neat freak.
I need a jump start with this.
Users browsing this forum: No registered users and 19 guests
