Fairlead Mount Blocks
Postby BobDz » Wed Apr 10, 2024 8:28 pm
I've been experimenting...
Got tired of waiting for parts so I ordered 3/4" phenolic on my own. HDPE came up as an alternative. For fun, I ordered a piece of that as well.
The mounting block is a pretty "inert" piece. In a simpler world it would probably be a block of wood. Not much force or stress applied to this piece. It's sole purpose is to provide a stable hole for the nylon cable fairleads. Pretty simple.
So I made both. Here are the results of my "experiment ".
HDPE is much lighter in weight.
HDPE is quite a bit cheaper.
HDPE machines VERY easily.
Phenolic is a bit more difficult to machine.
Can't think of a reason not to use HDPE.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Re: Fairlead Mount Blocks
Postby Bryan Cotton » Wed Apr 10, 2024 10:46 pm
I was going to say wear, but then I remembered the nylon insert.
How much weight does it save?
Postby BobDz » Sat Apr 13, 2024 12:00 pm
Bryan
1.1 ounce each
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Postby Area 51% » Sat Apr 13, 2024 12:43 pm
That must be extremely light stuff you're working with. Each of my blocks is just barely over an ounce to start with.
Postby peter anson » Sat Apr 13, 2024 4:06 pm
When I built my Sonex I made nearly all the phenolic parts from nylon; fairleads, rudder pedal bearings and flap tube bearings. On the bearing blocks I added an aluminium plate to spread the bolt load which I don't think was called in the original drawings. I wasn't trying to experiment; it was just a matter of using material that was available. In fact the only place I used phenolic material was for the the canopy latch striker plates because I happened to have some 1/4" sheet. After 12 years and 500 hours all the nylon parts are still working fine and have presented no problems.
Postby BobDz » Sat Apr 13, 2024 5:32 pm
Area 51% wrote:That must be extremely light stuff you're working with. Each of my blocks is just barely over an ounce to start with.
I have to say that I wasn't impressed with the phenolic I received. It was heavy, and very hard to drill. Not like any phenolic I had used before.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Postby BobDz » Sat Apr 13, 2024 5:39 pm
I'm actually wondering why Derlin is called out in the plans for thr Flap Tube mounting blocks. Derlin is typically used for machined parts like gears and splined shafts - things that require high strength. I would have thought UHMW plastic would have been used. In the woodworking world UHMW is called "slippery plastic". It's a great bearing material, especially in a situation like the Flap Tube which isn't high stress, or high use.
I'm pretty sure I'm using UHMW.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Return to Sonex-B / Waiex-B
