Cable Fairing
Cable Fairing
Postby BobDz » Sun Mar 24, 2024 10:45 pm
Evening Fellow Builders
Not sure I can bring myself to to mount the rudder cable fairings on the outside of the Skin.
I was thinking of using epoxy to mount a few nut plates on the back side of the fairing and install them on the inside of the skin with a flat head machine screw.
Has anyone done anything similar?
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Re: Cable Fairing
Postby Bryan Cotton » Mon Mar 25, 2024 9:36 am
Make them out of aluminum and then you don't have to hide them.
viewtopic.php?f=39&t=578&start=1020
Re: Cable Fairing
Postby Bryan Cotton » Mon Mar 25, 2024 9:43 am
Re: Cable Fairing
Postby daleandee » Mon Mar 25, 2024 10:38 am
I know some of you like to make every part and I commend that. But these are cheap enough and can be attached with some grey RTV or glue ...
https://www.aircraftspruce.com/catalog/ ... irings.php
Dale
3.0 Corvair/Tailwheel
Re: Cable Fairing
Postby BobDz » Mon Mar 25, 2024 11:15 am
Bryan Cotton wrote:Make them out of aluminum and then you don't have to hide them.
http://www.sonexbuilders.net/viewtopic. ... start=1020
Thanks Bryan. That was on my list to consider.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Re: Cable Fairing
Postby BobDz » Mon Mar 25, 2024 11:16 am
daleandee wrote:I know some of you like to make every part and I commend that. But these are cheap enough and can be attached with some grey RTV or glue ...
Dale
Another good option. Thank you Dale.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Return to Sonex-B / Waiex-B
