Access Holes
Access Holes
Postby BobDz » Wed Jan 24, 2024 6:51 pm
Was reviewing the fuselage plan pages today and thinking about the 4" diameter access holes (and for that matter ANY access holes. I'm thinking of riveting in countersunk nut plates. Then dimpling the holes on the access cover and using a countersunk screw.
Too crazy?
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Re: Access Holes
Postby BRS » Wed Jan 24, 2024 10:32 pm
Will look nice. The trade off is weight.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Re: Access Holes
Postby Bryan Cotton » Wed Jan 24, 2024 11:23 pm
This must be a B model thing. The access plates on my classic A model Waiex are a big rectangular one under the mixer, and two little circle ones under the aileron bellcranks. They are not dimpled for flush screws, but instead have normal pan head screws holding them on.
On my Hummelbird, every cover was done with nutplates and flush screws. The nutplates I used have a dimple for both the screw and the AN426-3 rivets, so it really does not weigh any more. If you want to use normal nutplates then you need a thicker piece of aluminum to countersink for the dimple in the cover. Then you get into extra weight like Brock says.
This is a whatever floats your boat thing, I think.
Return to Sonex-B / Waiex-B
