Bryan Cotton wrote:I know one was made down in Area 51. The cool thing was that it was lighter. I'd consider it if I built another. I've had no issues with my poly tank.
Area 51% wrote:The one I made was 3lbs lighter than the plastic job. It also holds another 3 gallons because I made it to fit under the glare shield better than the stock tank.
Never had a fitting pull loose either.
kmacht wrote:Just make sure you think through unintended consequences. An aluminum tank sitting right over your legs may not be the best idea in a crash. The plastic rotomolded tank is much more durable
kmacht wrote:It's experimental aircraft so it's up to you to choose. I just want to point out that the other planes mentioned that have aluminum fusealage tanks also don't have a better and safer option like the sonex does. .
