Arbor Press
Arbor Press
Postby BobDz » Fri Oct 20, 2023 12:34 pm
Is the Harbor Freight 1 ton press sufficient to put the 35 degree bend into the T12-07 Forward Spar Fitting?
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Re: Arbor Press
Postby kmacht » Fri Oct 20, 2023 12:48 pm
It’s overkill. Most have done it with a simple jig made of 3 pieces of pipe squeezed with a regular vice. It’s aluminum, not steel and bends relatively easily.
Re: Arbor Press
Postby BobDz » Fri Oct 20, 2023 1:02 pm
Vise worked great!
Thanks for that tip.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Re: Arbor Press
Postby mike.smith » Tue Oct 24, 2023 5:58 pm
Return to Sonex-B / Waiex-B
