First of all, Area 51% is an awesome handle.Area 51% wrote:I may be wrong, but I assume the B spars are nearly identical to the Legacy units.
On my legacy print it shows AN470AD5-6 rivets on either side of the stiffener and an AN470AD5-8 that goes through both the stiffener and cap.
None of that means anything if Sonex also drilled the bolt holes which will be a 3/16 hole. Diameter notwithstanding, the rivet lengths should still be the same.
