Flap Drive Tube
Flap Drive Tube
Postby JFYrineo » Fri Apr 07, 2023 7:03 am
The printsSNB-C05 call for the flap drive tube to “rotate freely”, any idea on how this equates to force? What’s too much, what’s not enough?
JFYrineo
Re: Flap Drive Tube
Postby Area 51% » Fri Apr 07, 2023 7:18 am
I asked that question of a long-time machinist and his answer was it's a " light, thumb-sucking fit".
Worked well for me.
Re: Flap Drive Tube
Postby JFYrineo » Sat Apr 08, 2023 5:30 am
Well thats a well calibrated and traceable international standard hahahaha (and I’m a retired manufacturing engineer of 35 years)
JFYrineo
Re: Flap Drive Tube
Postby pappas » Sat Apr 08, 2023 11:14 am
Remember that failing to remove the powder coat from the areas that rotate in the phenolic can make them difficult to operate smoothly. I always remove the powder coat with a torch and wire brush, then grease after cooling, before installing them. A torch melts the powder coat and a wire brush removes it from the area I need in just a minute or two. It works so much better that way.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
pappas
Return to Sonex-B / Waiex-B
