Spaceman wrote:I put mine under the seat like this:
http://paegelow.blogspot.com/2020/02/au ... 7.html?m=1
sonex892. wrote:Spaceman wrote:I put mine under the seat like this:
There is some really good info on Chris's blog. This is very similar to the mgl servo installation in my A model.
One thing that may not be apparent with this roll servo location, is the roll movement is 3 dimensional and the roll servo arm position alters with forward and aft stick movement. The servo end stop position for hard left aileron with stick forward is not the same servo end stop position as hard left aileron with stick aft. The same goes for the right aileron. I too had to fabricate a longer servo arm for the roll servo to reduce the total angle of throw to eliminate the risk of going over center and locking the controls.
DCASonex wrote:sonex892. wrote:Spaceman wrote:I put mine under the seat like this:
I addressed this by mounting my roll servo off the base frame of my center stick so it moves with the stick. Where I located it, Its mass also helps offset some of the added pull from the bungee cord as it is stretched as stick is pushed forward.
DCASonex wrote:Dale,
Photos and drawings can be found on the Sonex Foundation website:
https://sonexfoundation.com/the-amsler-files
Under heading of autopilot, which is the first in the list of my customizations.
Users browsing this forum: No registered users and 33 guests
