Pretty Sure I Ruined My Spar
Postby lakespookie » Tue May 03, 2022 1:17 am
So after not building for 2 months, I finally got a normal weekend with some time off and went off to work on my main spar. Well low and behold i forgot how to notice the little details in the plans and though i was placing the spar attach angle in the right place instead i placed it where i belive rib 1 goes on the left spar, after getting through the rest of the parts that go on the spar without issue i was looking over the plans in preperation for working on the right spar and i noticed a little measurement and it hit me, I made a huge fubar. so now i have 8 perfectly reamed tight fit holes on a spar where a rib should go!!!!
Lets just say this has not been my year, between a 3 month covid recovery, a car accident in this market (Currently waiting 12 of 20 more weeks on a car i ordered; there goes all the disposable build income lolz) and working like a crazy person the last thing i needed was to destroy a 2k spar, In other news stuff happens i will get the right spar right and hope i can salvage this spar with some input from the factory.
Right now my only hope is that i can mount the rib with the screws and a backing plate but that will most likley cause serious edge clearance issues but who knows if anyone has screwed up worst than this i could use some encouragement!!!!
Jill's Build Log
PPL-ASEL
Tail = Complete
Wings = Complete
Waiex-B 0054
Panel G3X
lakespookie
Re: Pretty Sure I Ruined My Spar
Postby GordonTurner » Tue May 03, 2022 7:48 am
Send pictures and a drawing of what you think might be a repair to Sonex. Chances are they will assess and work with you.
Gordon
Postby lakespookie » Mon May 09, 2022 10:00 pm
Got the OK from the factory to use bolts in place of rivets for the rib mounting and to make up for the swiss cheese I created.
for refrence check out the build log.
Jill's Build Log
PPL-ASEL
Tail = Complete
Wings = Complete
Waiex-B 0054
Panel G3X
lakespookie
Postby Murray Parr » Tue May 10, 2022 4:20 pm
The root rib has an angle braket which uses AN3 bolts (at least on the B model ). Could you not just make new brackets to suit the holes you have already drilled?
Murray Parr
WXB0015
Rotax 912ULS
MGL Explorer Lite
First flight May 6/23
RV9 builder (Sold)
Murray Parr
Postby lakespookie » Wed May 25, 2022 8:30 pm
I drilled the holes on the location for RIB 1 to the outside of where the attachment angle should go. The concern was more so with the swiss cheese i created and any potential structural weaknesses over how to mount the messup.
Jill's Build Log
PPL-ASEL
Tail = Complete
Wings = Complete
Waiex-B 0054
Panel G3X
lakespookie
Return to Sonex-B / Waiex-B
