pfhoeycfi wrote:I drilled a hole in the glareshield with a unibit. My tubing runs between the glareshield and windscreen...
sjakulski wrote:Per the dimensions on my plans I placed the vent line fitting hole in the fuel tank. I note in test fitting the tank with the glareshield, however, that the fitting does not fall within the glareshield cutout made for the gas cap? Is it supposed to? If so, the plan dimensions are wrong for the hole location (would not the first time for these plans) and I have to plug and redrill another vent hole in the tank, or I could drill a hole in the glareshield for the fitting to pass through? The plans would lead me to believe that the vent fitting and line runs under the glareshield to exit. But, no way the fitting is going to fit under the glareshield. The top of the tank is too close to the bottom of the glareshield.
What say ye before me? Thanks
